Bush Washing Machine Spare Parts
Bush Washing Machine spares for most leading brands including the most popular spare parts and many low-cost compatible or alternative spares where these are available.
Here you can find all the popular Bush Washing Machine parts and many more spares for your machine.
If you can't find the Bush Washing Machine spares you need or are unsure, please contact us for more help or you can use our Bush Washing Machine_support forum to get free help (including diagnostic and fault finding help) even outside business hours from engineers. By asking us by email we can often also cross reference spares and offer you more than one choice which will very often save you money on spare parts.
Washing Machine Fixing Kit
Suitable for use on most Washing Machines. Please check suitability before ordering. More InformationIn stockIn stock£4.99 -
Universal Washing Machine T Tap - Red
Suitable for use on most Washing Machines. Please check suitability before ordering. More InformationOut of stockOut of stock£19.49 -
Washing Machine Sump Hose
Washing Machine Drum Lifter
Genuine replacement dum paddle or lifter to fit the washing machine and washer dryer models as shown More InformationIn stockIn stock£9.99 -
Washing Machine Door Handle
Low cost compatible door handle to fit eh Zanussi washing machine models shown but may fit other makes and models as advised More InformationOut of stockOut of stock£4.99 -
Washing Machine Door Lock
Door safety interlock or door lock to fit the washing machine models as shown or as directed as can fit a number of different brands More InformationOut of stockOut of stock£41.49 -
Washing Machine Solenoid Valve - 12mm 180 Degree
Low cost compatible twin solenoid water inlet or fill valve to fit Beko, Candy and many other washing machine models as shown or as advised More InformationIn stockIn stock£40.49 -
Washing Machine Dispenser Hose
Hose that runs from the soap dispenser to the tub or tank of the washing machine models shown and others as advised as can be found fitted to other makes and models More InformationIn stockIn stock£13.49 -
Washing Machine Temperature Sensor NTC
Genuine spare part for a range of Amica, Bush, Currys Essentials, Gorenje, Kenwood and other branded Washing Machines. More InformationIn stockIn stock£7.49
