Bush Hoses
Bush Hoses used in popular appliances. There are a number of cheap low cost alternative Bush Hoses as well as the genuine ones.
If you are unsure or can't find the Bush Hoses that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Bush Hoses forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Universal Tumble Dryer Vent Hose 4 Metre 4 Inch
Suitable for use on most Tumble Dryers. Please check suitability before ordering. More InformationIn stockIn stockSpecial Price £12.49 Regular Price £16.99 -
22mm drain hose connector used on many washing machines and dishwashers More InformationOut of stockOut of stock£5.99 -
Washing Machine Sump Hose
Genuine replacement sump hose that connects from the bottom of the tub to tank of the washing machine to the drain pump housing on the models as shown More InformationIn stockIn stock£25.49 -
Suitable for use on most Washing Machine|Dishwashers. Please check suitability before ordering. More InformationIn stockIn stock£8.99
Finding Bush Hoses can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Bush Hoses or any other spare part please ask for assistance as we're only too happy to help you.
