Blomberg Spare Parts
Blomberg spares for most leading brands including the most popular spare parts and many low-cost compatible or alternative spares where these are available.
Here you can find all the popular Blomberg parts and many more spares for your machine.
If you can't find the Blomberg spares you need or are unsure, please contact us for more help or you can use our Blomberg_support forum to get free help (including diagnostic and fault finding help) even outside business hours from engineers. By asking us by email we can often also cross reference spares and offer you more than one choice which will very often save you money on spare parts.
Washing Machine Water Inlet Valve
Genuine water fill solenoid or water inlet valve with special connectors to fit washing machine models as shown More InformationIn stockIn stock£27.49 -
Tumble Dryer Drive Belt - 4PHE285
Low cost compatible replacement belt used on Beko tumble dryer models as listed or as directed as may fit other models not shown More InformationIn stockIn stockSpecial Price £15.49 Regular Price £29.99 -
Universal Washing Machine & Dishwasher Hose Clamp (Pack of 10) - 20 - 32mm
Tumble Dryer Door Lock
Genuine replacement part. Suitable for a range of Beko and other branded Tumble Dryers. More InformationOut of stockOut of stock£9.99 -
Tumble Dryer Control Panel Light Guide
Small clear plastic insert that sits behind the buttons on the tumble dryer models as shown or as advised More InformationIn stockIn stock£7.25 -
Washing Machine Door Hinge
Genuine replacement part. Suitable for a range of Beko and other branded Washing Machines. More InformationIn stockIn stock£16.49 -
Washing Machine Thermal Cut Out
Washer dryer, dryer side thermal cut out mounted on the top of the dryer unit More InformationIn stockIn stock£14.99 -
Replacement washing machine & washer dryer drum bearing for machines. More InformationOut of stockOut of stock£8.49 -
Washing Machine Sump Hose
Genuine Beko washing machine sump hose including the detergent ball More InformationIn stockIn stock£16.99 -
Washing Machine Hinge
Outer door hinge for the wooden door to fit integrated washing machine and washer dryer models More InformationIn stockIn stock£27.49
