Balay Seals
Balay Seals used in popular appliances. There are a number of cheap low cost alternative Balay Seals as well as the genuine ones.
If you are unsure or can't find the Balay Seals that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Balay Seals forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Tumble Dryer Felt Bearing Seal
Genuine replacement front felt seal to fit the tumble dryer models as shown or as directed as can fit models not listed More InformationIn stockIn stock£37.99 -
Washing Machine Seal - 289500
Low cost compatible replacement door seal or gasket to fit many washing machine models from Bosch, Neff and Siemens More InformationIn stockIn stock£31.49 -
Washing Machine Bearing Seal 30 x 53.5 x 10/14mm
Washing Machine Seal - 680405
Low cost compatible washing machine door seal to fit models from Bosch and Siemens More InformationIn stockIn stock£26.49 -
Washing Machine Door Seal
Genuine replacement washing machine door seal to fit the models shown but can fit other models from Neff and Siemens as directed including integrated models More InformationIn stockIn stock£103.99 -
Genuine replacement part. Suitable for a range of Bosch, Neff and Siemens Washing Machines. More InformationIn stockIn stock£126.49 -
Genuine Bosch washer dryer rubber gasket or door seal bellows to fit washer dryer models More InformationIn stockIn stock£71.49 -
Washing Machine Door Seal (Kit)
Genuine replacement part. Suitable for a range of Bosch, Neff and Siemens Washing Machines. More InformationIn stockIn stock£80.99 -
Washing Machine Door Seal Clamp
Genuine replacement part. Suitable for a range of Bosch, Neff and Siemens Washing Machines. More InformationIn stockIn stock£10.49 -
Suitable for use on most Washing Machines. Please check suitability before ordering. More InformationIn stockIn stock£10.75
Finding Balay Seals can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Balay Seals or any other spare part please ask for assistance as we're only too happy to help you.
