Swan Shelves
Swan Shelves used in popular appliances. There are a number of cheap low cost alternative Swan Shelves as well as the genuine ones.
If you are unsure or can't find the Swan Shelves that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Swan Shelves forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Fridge Freezer Shelf Rear Trim
Rear shelf plastic trim to fit the models as shown and others as advised many of which are built in or integrated More InformationIn stockIn stock£15.49 -
Fridge Freezer lower Bottle Shelf
Genuine replacement part. Suitable for a range of Beko and other branded Fridge and Freezers. More InformationOut of stockOut of stock£15.99 -
Large bottle storage shelf used in Lamona built in or integrated fridges and fridge freezers More InformationIn stockIn stock£11.99 -
Genuine replacement door storage shelf used on the upper or middle positions depending on the model that this shelf is fitted to More InformationIn stockIn stock£15.49 -
Fridge Freezer Bottom Bottle Shelf
Fridge Freezer Glass Shelf Trim - 54cm - Front
Front plastic glass fridge shelf trim to fit the models as shown and others as advised More InformationIn stockIn stock£13.99 -
Fridge Freezer Glass Shelf - Upper
Genuine replacement part. Suitable for a range of Beko and other branded Fridge and Freezers. More InformationIn stockIn stock£17.49 -
Larger fridge door bottle shelf to fit the models as shown or as directed More InformationOut of stockOut of stock£14.49 -
Cooker Full Width Shelf - 395mm x 365mm
Genuine plastic rear shelf trim that fits to the rear of the larger glass shelves used in the models as listed, most of which are integrated models More InformationIn stockIn stock£16.49
Finding Swan Shelves can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Swan Shelves or any other spare part please ask for assistance as we're only too happy to help you.
