Philips Cooker & Oven Heaters & Elements
Philips Cooker & Oven Heaters & Elements used in popular appliances. There are a number of cheap low cost alternative Philips Cooker & Oven Heaters & Elements as well as the genuine ones.
If you are unsure or can't find the Philips Cooker & Oven Heaters & Elements that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Philips Cooker & Oven Heaters & Elements forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Universal Cooker Fan Oven Element - Long Neck
Cooker Grill Element - 900 + 1600 Watt
Suitable for a range of Whirlpool and other branded cookers. This Grill Element is a high quality replacement spare part manufactured by a UK Whitegoods Approved Supplier More InformationIn stockIn stock£19.49 -
Cooker Fan Oven Element - 2000 Watt - C00283438
Quality compatible replacement part for a range of Ariston, Bauknecht, Creda, Hotpoint, Ignis, Indesit, and Whirlpool Cooker and Ovens. More InformationIn stockIn stockSpecial Price £24.49 Regular Price £29.99 -
Suitable for use on most Cooker and Ovens. Please check suitability before ordering. More InformationOut of stockOut of stockSpecial Price £25.49 Regular Price £31.99
Finding Philips Cooker & Oven Heaters & Elements can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Philips Cooker & Oven Heaters & Elements or any other spare part please ask for assistance as we're only too happy to help you.
