Leisure Thermostats
Leisure Thermostats used in popular appliances. There are a number of cheap low cost alternative Leisure Thermostats as well as the genuine ones.
If you are unsure or can't find the Leisure Thermostats that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Leisure Thermostats forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Fridge Freezer Thermostat Control Knob
Genuine replacement part. Suitable for a range of Beko and other branded Fridge and Freezers. More InformationIn stockIn stock£5.75 As low as £4.49 -
Suitable for use on most Fridge and Freezers. Please check suitability before ordering. More InformationIn stockIn stock£6.99 -
Fridge Freezer Air Sensor Kit
Air temperature sensor used in electronically controlled fridges and fridge freezers including built in or integrated models More InformationIn stockIn stock£7.99 -
Cooker Thermostat Kit
Genuine replacement gas oven thermostat used in the Rangemaster etc range cookers as shown or as advised only More InformationIn stockIn stock£108.99 -
Cooker Grill Thermocouple
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£12.99 -
Fridge Freezer Thermostat - KDF25L3
Genuine replacement thermostat used on units as advised More InformationIn stockIn stock£24.49 -
Cooker Cooling Fan Motor TOC
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£12.49 -
Cooker Oven Thermostat
hugely popular oven thermostat that is used on a huge range of built in oven and cookers with a range of 50-320ËšC and this compatible version will normally be hugely cheaper More InformationIn stockIn stockSpecial Price £17.49 Regular Price £27.99 -
Cooker Oven Thermal Switch - 80°C - 250°C
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£11.99 -
Cooker Thermostat
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£23.49
Finding Leisure Thermostats can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Leisure Thermostats or any other spare part please ask for assistance as we're only too happy to help you.
