Fridge & Freezer Hinges
Fridge & Freezer Hinges used in popular appliances. There are a number of cheap low cost alternative Fridge & Freezer Hinges as well as the genuine ones.
If you are unsure or can't find the Fridge & Freezer Hinges that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Fridge & Freezer Hinges forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Fridge Freezer Door Hinge - Upper Right/Lower Left
Genuine Smeg replacement door hinge to fit integrated fridge and freezer models as shown or as directed More InformationIn stockIn stock£55.49 -
Fridge Freezer Integrated Door Fitting Kit
Integrated door mounting kit to fix the outer wooden furniture or kitchen door to the models as shown or as advised More InformationIn stockIn stock£30.99 -
Frigidaire Fridge Freezer Upper Door Hinge
Genuine spare part for a range of Fridgidaire Fridge and Freezers. More InformationIn stockIn stock£3.49 -
Fridge Freezer Lower Door Hinge
Genuine replacement spare part. Suitable for a range of Hoover and Candy Fridge and Freezers. More InformationIn stockIn stock£58.99 -
Fridge Freezer Integrated Door Hinge - Upper
Genuine replacement spare part. Suitable for a range of Hoover and Candy Fridge and Freezers. More InformationIn stockIn stock£58.49 -
Fridge Freezer Door Hinge Bush - 4x15mm - White
For a range of Hotpoint, Indesit and other branded Fridge and Freezers. Genuine spare part. More InformationIn stockIn stock£14.49 -
Fridge Freezer Integrated Door Hinge kit - C00310966
Suitable for use on most Fridge and Freezers. Please check suitability before ordering. More InformationIn stockIn stock£61.49 -
Fridge Freezer Door Hinge - Left Hand Side
Fridge Freezer Door Hinge Bracket
Small metal right angel connection bracket used to affix the furniture door to the fridge or freezer door of the models shown More InformationIn stockIn stock£7.25 -
Fridge Freezer Door Bearing & Pin
Genuine replacement part. Suitable for a range of Bosch, Neff and Siemens Fridge and Freezers. More InformationIn stockIn stock£11.49
Finding Fridge & Freezer Hinges can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Fridge & Freezer Hinges or any other spare part please ask for assistance as we're only too happy to help you.
