Neff Fridge & Freezer Hinges
Neff Fridge & Freezer Hinges used in popular appliances. There are a number of cheap low cost alternative Neff Fridge & Freezer Hinges as well as the genuine ones.
If you are unsure or can't find the Neff Fridge & Freezer Hinges that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Neff Fridge & Freezer Hinges forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Fridge Door Lower Bushing - Right
Genuine replacement part. Suitable for a range of Bosch, Neff and Siemens Fridge and Freezers. More InformationIn stockIn stock£6.99 -
Fridge Door Upper Hinge
Fridge or freezer door hinge that is also used on integrated or built in fridge freezers to fit the top of the door when hinged on the right hand side More InformationIn stockIn stock£12.49 -
Fridge Freezer Integrated Door Fixing Kit
Fitting pack for the integrated fridge and freezer models as shown or as directed More InformationIn stockIn stock£26.99 -
Fridge Freezer Door Hinge Kit
Genuine hinge repair kit that can be used to replace a door hinge set on either an integrated fridge or integrated freezer models More InformationIn stockIn stock£67.49 -
Neff Fridge Freezer Upper Door Hinge
Replacement spare part suitable for Neff Fridge Freezers. Genuine part from the original manufacturer. More InformationIn stockIn stock£87.49 -
Neff Fridge Freezer Lower Door Hinge
Fridge Door Lower Door Hinge
Fridge or freezer door hinge that is also used on integrated or built in fridge freezers to fit the bottom of the door when hinged on the right hand side More InformationIn stockIn stock£11.99 -
Mounting kit to fix the outer wooden kitchen cabinet door to the fridge or freezer door of the models shown and others on advice as can fit more models than listed More InformationIn stockIn stock£49.49 -
Fridge Freezer Door Pin Set
Genuine Bosch Spares replacement inner freezer compartment plastic door hinge to fit fridge models from Bosch, Neff and Siemens More InformationIn stockIn stock£7.49 -
Fridge Freezer Door Hinge Bush
Replacement inner freezer compartment plastic door hinge bush to fit a number of fridge models More InformationIn stockIn stock£19.99
Finding Neff Fridge & Freezer Hinges can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Neff Fridge & Freezer Hinges or any other spare part please ask for assistance as we're only too happy to help you.
