Flavel Thermostats
Flavel Thermostats used in popular appliances. There are a number of cheap low cost alternative Flavel Thermostats as well as the genuine ones.
If you are unsure or can't find the Flavel Thermostats that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Flavel Thermostats forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Fridge Freezer Thermostat
Suitable for use on most Fridge and Freezers. Please check suitability before ordering. More InformationIn stockIn stock£9.99 -
Suitable for use on most Fridge and Freezers. Please check suitability before ordering. More InformationIn stockIn stock£10.99 -
Cooker Oven Thermal Cut Out
Genuine thermal cut out thermostat used on the range cooker models as shown or as advised as may fit others More InformationIn stockIn stock£35.49 -
Cooker Thermostat - Ego 55.17069.030
Low cost compatible oven thermostat to fit built oven and cooker models as shown and for double ovens this is normally the main oven thermostat More InformationIn stockIn stock£24.49 -
Suitable for use on most Cooker and Ovens. Please check suitability before ordering. More InformationOut of stockOut of stock£6.99 -
Fridge Freezer Thermostat - Ranco - K59 - L2680
Genuine replacement part. Suitable for a range of Beko and other branded Fridge and Freezers. More InformationIn stockIn stock£27.49 -
Cooker Thermostat
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£65.99
Finding Flavel Thermostats can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Flavel Thermostats or any other spare part please ask for assistance as we're only too happy to help you.
