Flavel Seals
Flavel Seals used in popular appliances. There are a number of cheap low cost alternative Flavel Seals as well as the genuine ones.
If you are unsure or can't find the Flavel Seals that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Flavel Seals forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Fridge Freezer Door Seal
Genuine replacement part. Suitable for a range of Beko and other branded Fridge and Freezers. More InformationOut of stockOut of stock£19.99 -
Door seal used on the makes and models as shown or only as advised More InformationOut of stockOut of stock£21.49 -
Cooker Main Oven Door Seal
Genuine replacement oven door seal used on the make sand models of cooker as shown More InformationIn stockIn stock£17.49 -
Cooker Main Oven Door Seal - 4 Sided
Door seal or gasket to fit the freezer door on the fridge freezer models as listed More InformationIn stockIn stock£20.49 -
Cooker Outer Glass Seal
Outer door glass seal to fit the models as shown or as advised More InformationIn stockIn stock£9.99 -
Cooker Door Seal
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£9.49 -
Cooker Main Oven Door Glass Seal
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£32.49 -
Cooker Door Seal - Top Oven
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£12.99 -
Door seal or gasket to fit the fridge freezer models as listed and can be used as a fridge or freezer gasket depending on the model More InformationOut of stockOut of stock£35.99
Finding Flavel Seals can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Flavel Seals or any other spare part please ask for assistance as we're only too happy to help you.
