Flavel Seals
Flavel Seals used in popular appliances. There are a number of cheap low cost alternative Flavel Seals as well as the genuine ones.
If you are unsure or can't find the Flavel Seals that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Flavel Seals forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Fridge Freezer Door Seal
Door seal or gasket to fit fridge and fridge freezer models as listed or as directed More InformationOut of stockOut of stock£24.49 -
Cooker Door Seal - 30cm
Genuine replacement small oven door seal used on the make sand models of cooker as shown More InformationIn stockIn stock£17.49 -
Cooker Oven Door Seal - 40cm - Right Hand Side Tall Oven
Door gasket used on the tall oven, normally the right hand one, of the cooker models as shown More InformationIn stockIn stock£18.99 -
Cooker Door Seal - 3 Sided - 400mm x 340mm
Genuine Rangemaster Spares replacement oven door seal or gasket to fit models from Leisure and Rangemaster More InformationIn stockIn stock£32.49 -
Cooker Door Seal
Low cost compatible oven door seal for the outer door glass of the built in oven and cooker models as shown More InformationIn stockIn stock£17.99 -
Cooker Main Oven Door Seal
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£17.99 -
Cooker Door Hinge Seal
Small gasket or spacer used on the oven door hinges of the Rangemaster 110 range cooker among other models as shown or as directed More InformationIn stockIn stock£3.49 -
Cooker Inner Glass Seal - Top Oven
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£10.99 -
Cooker Door Seal - 380mm x 330mm
Replacement main oven door seal to fit the make and models as show or as advised More InformationIn stockIn stock£10.99 -
Dishwasher Door Seal
Genuine replacement 3 sided upper door seal to fit the dishwasher models shown including built in or integrated dishwasher models More InformationIn stockIn stock£15.99
Finding Flavel Seals can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Flavel Seals or any other spare part please ask for assistance as we're only too happy to help you.
