Flavel Burners & Caps
Flavel Burners & Caps used in popular appliances. There are a number of cheap low cost alternative Flavel Burners & Caps as well as the genuine ones.
If you are unsure or can't find the Flavel Burners & Caps that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Flavel Burners & Caps forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Cooker Medium Burner Cap
Medium sized burner cap used in the various built in gas hob and gas cooker models as shown or as directed More InformationIn stockIn stock£9.25 -
Cooker Burner Head - 2KW
Medium burner body used on the gas hob and cooker models as shown or as advised More InformationIn stockIn stock£13.99 -
Cooker Burner Protection Sheet
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£11.99 -
Cooker Rapid Burner Cap - 3KW
Large 3KW burner cap to fit the various models as shown or as directed as can be used on models using the same burner rings not listed More InformationIn stockIn stock£12.99 -
Cooker Hob Pan Support - 487mm x 232mm
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£24.49 -
Cooker Small Burner Cap
Auxilliary or small Burner cap used on the built in gas hob and cooker models as shown or as directed if your model is not listed More InformationIn stockIn stock£7.99 -
Cooker Medium Burner Cap - 2KW
Cooker Burner Cap - 1KW
Small 1KW burner cap to fit the various models as shown or as directed as can be used on models using the same burner rings not listed More InformationIn stockIn stock£5.99 -
Cooker Hob Large Burner Head
Large 3KW burner to fit the various models as shown or as directed as can be used on models using the same burner rings not listed More InformationIn stockIn stock£15.99 -
Cooker Burner & Electrode
Genuine replacement part. Suitable for a range of Flavel, Leisure and Rangemaster Cooker and Ovens. More InformationIn stockIn stock£70.99
Finding Flavel Burners & Caps can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Flavel Burners & Caps or any other spare part please ask for assistance as we're only too happy to help you.
