Grundig Cooker & Oven Spare Parts
Grundig Cooker & Oven spares for most leading brands including the most popular spare parts and many low-cost compatible or alternative spares where these are available.
Here you can find all the popular Grundig Cooker & Oven parts and many more spares for your machine.
If you can't find the Grundig Cooker & Oven spares you need or are unsure, please contact us for more help or you can use our Grundig Cooker & Oven_support forum to get free help (including diagnostic and fault finding help) even outside business hours from engineers. By asking us by email we can often also cross reference spares and offer you more than one choice which will very often save you money on spare parts.
Cooker Timer
Digital timer or electronic clock used in a number of cookers and built-in ovens More InformationIn stockIn stock£62.49 -
Cooker Hob Burner Body - 1kW
Small auxiliary burner body used on the gas hob and cooker models as shown or as advised More InformationIn stockIn stock£12.99 -
Cooker Front Door
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£49.49 -
Cooker Door Handle
Stainless oven door handle used on the Flavel cooker models as shown only More InformationIn stockIn stock£55.49 -
Cooker Top Oven Door Hinge
Top oven door hinge used on double oven, cookers with upper grill and oven compartments and range cookers. More InformationIn stockIn stock£14.99 -
Cooker Outer Door Glass
Genuine replacement oven outer door glass unit to exclusively fit the Lamona models as shown or only as directed More InformationIn stockIn stock£49.49 -
Cooker Thermocouple
Grill and oven thermocouple to fit a wide range of free-standing gas cookers and gas ovens More InformationOut of stockOut of stock£24.49 -
Cooker Terminal Block
Mains terminal block used on oven, cooker and hob models as shown or only as adised More InformationIn stockIn stock£18.49 -
Cooker Thermocouple
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£20.99 -
Cooker Hotplate - 1700 Watt
Large 1700 Wat ceramic hob heating element or some to fit the cooker and hob model as shown or as directed if your model is not listed More InformationIn stockIn stock£46.99
