Diplomat Cooker & Oven Spare Parts
Diplomat Cooker & Oven spares for most leading brands including the most popular spare parts and many low-cost compatible or alternative spares where these are available.
Here you can find all the popular Diplomat Cooker & Oven parts and many more spares for your machine.
If you can't find the Diplomat Cooker & Oven spares you need or are unsure, please contact us for more help or you can use our Diplomat Cooker & Oven_support forum to get free help (including diagnostic and fault finding help) even outside business hours from engineers. By asking us by email we can often also cross reference spares and offer you more than one choice which will very often save you money on spare parts.
Base Cooker Element - 1200 Watt
Cooker Outer Door
Main oven outer door glass panel to fit the Beko oven and cooker models as shown More InformationIn stockIn stock£60.99 -
Diplomat Cooker Thermostat
Suitable for a range of Diplomat, Hygena and Servis cookers. This Thermostat is a genuine spare part made by the Original Manufacturer More InformationIn stockIn stock£57.49 -
Cooker Switch Pack
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£60.99 -
Diplomat Cooker Fan Oven Element - 2000 Watt
Suitable for a range of Diplomat, Hygena and Servis cookers. This Fan Oven Element is a genuine spare part made by the Original Manufacturer More InformationIn stockIn stock£70.99 -
Cooker Gas Hose 4ft Screw Fitting
Suitable for use on most Cooker and Ovens. Please check suitability before ordering. More InformationOut of stockOut of stock£30.49 -
Hob Control Knob
Hob control knob used on the built in oven, range cooker and cooker models as shown and others as instructed More InformationIn stockIn stock£10.49 As low as £5.99 -
Cooker Door Lock
Diplomat Cooker Screw
Genuine replacement side support pin or screw used for the shelf supports on the Smeg built in oven and cooker models shown More InformationIn stockIn stock£4.49 -
Cooker Thermostat Signal Lamp - Red
Red oven indicator lamp normally used to indicate the thermostat but can be used for power status of the built in oven and cooker models as listed or as directed if not shown More InformationIn stockIn stock£7.49
