Balay Cooker & Oven Spare Parts
Balay Cooker & Oven spares for most leading brands including the most popular spare parts and many low-cost compatible or alternative spares where these are available.
Here you can find all the popular Balay Cooker & Oven parts and many more spares for your machine.
If you can't find the Balay Cooker & Oven spares you need or are unsure, please contact us for more help or you can use our Balay Cooker & Oven_support forum to get free help (including diagnostic and fault finding help) even outside business hours from engineers. By asking us by email we can often also cross reference spares and offer you more than one choice which will very often save you money on spare parts.
Cooker Lower Heater Element
Genuine replacement lower oven heating element used in the makes and models as shown More InformationIn stockIn stock£38.99 -
Cooker Gas Hose 4ft Screw Fitting
Suitable for use on most Cooker and Ovens. Please check suitability before ordering. More InformationOut of stockOut of stock£30.49 -
Cooker Inner Door Glass
Genuine replacement inner door glass panel to fit the Neff oven models as shown only unless advised otherwise More InformationIn stockIn stock£161.49 -
Cooker Heater Element - 2100 Watt
Genuine Bosch spares replacement fan oven element to fit a wide range of Bosch and some Neff built in ovens and cookers More InformationIn stockIn stock£82.49 -
Cooker Door Hinge
Genuine oven door hinge to fit the models of built in oven and cooker as listed or as directed as can fit models not shown More InformationIn stockIn stock£121.49 -
Cooker Oven Base heating Element - 1000 Watt
Genuine replacement part. Suitable for a range of Bosch, Neff and Siemens Cooker and Ovens. More InformationIn stockIn stock£69.49 -
Cooker Dual Grill Element
Genuine grill element to fit Bosch manufactured cooker and built in oven models as listed or as advised More InformationIn stockIn stock£52.99 -
Cooker Timer
Electronic oven timer or clock unit to fit the models as shown or as directed if your model is not listed as can fit other models More InformationIn stockIn stock£134.99 -
Genuine replacement part. Suitable for a range of Bosch, Neff and Siemens Cooker and Ovens. More InformationIn stockIn stock£119.99 -
Cooker Thermostat
Oven temperature limiter used in the models as shown or as advised only More InformationIn stockIn stock£67.99
