Altus Cooker & Oven Spare Parts
Altus Cooker & Oven spares for most leading brands including the most popular spare parts and many low-cost compatible or alternative spares where these are available.
Here you can find all the popular Altus Cooker & Oven parts and many more spares for your machine.
If you can't find the Altus Cooker & Oven spares you need or are unsure, please contact us for more help or you can use our Altus Cooker & Oven_support forum to get free help (including diagnostic and fault finding help) even outside business hours from engineers. By asking us by email we can often also cross reference spares and offer you more than one choice which will very often save you money on spare parts.
Cooker Switch Button Body
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£12.49 -
Cooker Door Seal - 440mm x 340mm
Cooker Thermal Switch - 175 degrees
Thermal cut out switch to fit a number of different built in oven and cooker models. More InformationIn stockIn stock£11.99 -
Cooker Selector Switch - Grill
Cooker Burner Head - 2KW
Medium 2KW burner to fit the various models as shown or as directed as can be used on models using the same burner rings not listed More InformationIn stockIn stock£14.49 -
Cooker Safety Valve Button
Cooker Door Assembly Nut - M4
Inner door glass panel fixing nut (fitted to the door) to fit built in oven and cooker models More InformationIn stockIn stock£3.49 -
Cooker Medium Burner Cap
Medium sized burner cap used in the various built in gas hob and gas cooker models as shown or as directed More InformationIn stockIn stock£9.25 -
Cooker Door Seal - Main Oven
Genuine oven door seal for the inner door glass of the built in oven and cooker models as shown More InformationIn stockIn stock£8.50 -
Cooker Fan Oven Element - 1800 Watt
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£23.99
