Burners & Caps
Cooker Hob Wok Burner Cap - 4kW
Genuine replacement part. Suitable for a range of Belling, Stoves and New World Cooker and Ovens. More InformationIn stockIn stock£7.49 -
Cooker Hob Medium Burner Head
Replacement medium burner cap used on the models as shown or as advised More InformationIn stockIn stock£12.49 -
Whirlpool Cooker Hob Pan Support
Genuine replacement part for a range of Whirlpool Cookers More InformationIn stockIn stock£52.49 -
Cooker Rapid Burner Cap - 3KW
Large 3KW burner cap to fit the various models as shown or as directed as can be used on models using the same burner rings not listed More InformationIn stockIn stock£12.99 -
Smeg Cooker Hob Large Burner Head - 90mm
Burner base body or skirt to fit the Smeg built in gas hob and cooker models as shown More InformationIn stockIn stock£16.49 -
Gas Hob Burner Cap - 60mm
For a range of Hotpoint, Indesit and other branded Cooker and Ovens. Genuine spare part. More InformationIn stockIn stock£35.49 -
Cooker Hob Pan Support - 487mm x 232mm
Genuine replacement part. Suitable for a range of Beko and other branded Cooker and Ovens. More InformationIn stockIn stock£24.49 -
Cooker Hob Wok Burner Body - 3.3
Large wok burner used on the gas hob and cooker models as shown or as advised More InformationIn stockIn stock£29.99 -
Hotpoint Cooker Hob Double Pan Support
For a range of Hotpoint Cooker and Ovens. Genuine spare part. More InformationIn stockIn stock£38.99 -
Cooker Small Burner Cap
Auxilliary or small Burner cap used on the built in gas hob and cooker models as shown or as directed if your model is not listed More InformationIn stockIn stock£7.99
