Burners & Caps
Cooker Hob Large Burner Cap - 100mm
Large 3kW burner cap to fit Beko manufactured cooker and hob models. More InformationIn stockIn stock£13.49 -
Cooker Medium Burner Cap
Genuine replacement spare part. Suitable for a range of Electrolux, AEG, Zanussi and other branded Cooker and Ovens. More InformationIn stockIn stock£16.49 -
Cooker Bob Small Burner Ring - 65mm
Genuine replacement part. Suitable for a range of Belling, Stoves and New World Cooker and Ovens. More InformationOut of stockOut of stock£16.49 -
Smeg Cooker Semi Rapid Burner Cap - 75mm
Genuine replacement medium (semi rapid) burner cap to fit the built in gas hob and cooker models as shown More InformationIn stockIn stock£20.49 -
Cooker Burner Cap
Genuine replacement part for a range of Whirlpool and Ignis Cookers More InformationIn stockIn stock£19.99 -
Cooker Auxiliary Burner Cap - 55mm
Genuine replacement 55mm auxiliary or small burner cap used on the gas hob and cooker models as shown or as advised More InformationIn stockIn stock£15.99 -
Cooker Burner Head - 1KW
Small 1KW burner to fit the various models as shown or as directed as can be used on models using the same burner rings not listed More InformationIn stockIn stock£11.99 -
Cooker Oven Burner Cast
For a range of Hotpoint, Indesit and other branded Cooker and Ovens. Genuine spare part. More InformationIn stockIn stock£29.49 -
Cooker Burner Ring - Medium
For a range of Hotpoint, Indesit and other branded Cooker and Ovens. Genuine spare part. More InformationIn stockIn stock£25.49 -
Cooker Hob Burner Body - 1kW
Small auxiliary burner body used on the gas hob and cooker models as shown or as advised More InformationIn stockIn stock£12.99
