Britannia Heaters & Elements
Britannia Heaters & Elements used in popular appliances. There are a number of cheap low cost alternative Britannia Heaters & Elements as well as the genuine ones.
If you are unsure or can't find the Britannia Heaters & Elements that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Britannia Heaters & Elements forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Britannia Cooker Fan Oven Element - 2615 Watt - Z4
Fan oven element to fit Britannia range cookers as listed or as directed but this fan heating element does fit almost all models More InformationIn stockIn stock£40.49 -
Britannia Cooker Grill Element - 2500 Watt - A45878
Low cost compatible dual grill element made by EGO to fit the smaller oven cavity in a number of Britannia range cooker models as shown or as advised More InformationIn stockIn stock£30.49 -
Britannia Cooker Grill Element - 1630 + 870 Watt
Dual grill element to fit the smaller oven cavity in a number of Britannia range cooker models as shown or as advised More InformationIn stockIn stock£65.49 -
Britannia Cooker Grill Element - 2450 Watt - Z4
Genuine replacement Britannia grill heating element to fit 40cm ovens More InformationIn stockIn stock£82.49 -
Britannia Cooker Base Element - 870 / 1035 Watt - Z4 40cm
Genuine replacement Britannia lower oven heating element to fit the small 40cm ovens of Britannia range cookers More InformationIn stockIn stock£38.49
Finding Britannia Heaters & Elements can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Britannia Heaters & Elements or any other spare part please ask for assistance as we're only too happy to help you.
