Brandt Spare Parts
Brandt spares for most leading brands including the most popular spare parts and many low-cost compatible or alternative spares where these are available.
Here you can find all the popular Brandt parts and many more spares for your machine.
If you can't find the Brandt spares you need or are unsure, please contact us for more help or you can use our Brandt_support forum to get free help (including diagnostic and fault finding help) even outside business hours from engineers. By asking us by email we can often also cross reference spares and offer you more than one choice which will very often save you money on spare parts.
Universal Cooker Base Oven Shelf - 38cm x 32cm
Cooker Oven Door Seal 4 Sided - Length 2040mm - C00252588
Suitable for use on most Cooker and Ovens. Please check suitability before ordering. More InformationIn stockIn stockSpecial Price £13.49 Regular Price £19.99 -
Universal Cooker Door Handle - Cut To Size - White - Maximum Length 60cm With Ends - Towel Rail Type
This white rail type oven door handle is designed as a cut-to-fit replacement where the original oven or cooker door handle is no longer available or prohibitively expensive to replace More InformationIn stockIn stockSpecial Price £10.49 Regular Price £14.99 -
Universal Cooker Grill Pan - 232mmx404mm
Suitable for use on most Cooker and Ovens. Please check suitability before ordering. More InformationIn stockIn stock£24.49 -
Universal Cooker Large Grill Pan Assembly - Grill Pan 420mm x 300mm - Grid 385mm x 260mm - Includes x2 Clip On Pan Handles
Suitable for use on most Cooker and Ovens. Please check suitability before ordering. More InformationIn stockIn stock£38.99 -
Universal Cooker Hotplate - 1000 Watt - 4mm Rim 145mm
Universal 6 or 145mm 1000W solid universal cooker hotplate or solid hotplate type of hob and cooker element More InformationIn stockIn stock£20.49 -
Cooker Oven Door Seal 4 Sided Rounded Corners - 1 Piece - 2m
Universal oven and cooker door seal to fit types with a four sided seal that can fit a wide range of built in ovens and cookers More InformationIn stockIn stockSpecial Price £16.49 Regular Price £29.99 -
Cooker Fan Oven Element - 2000 Watt - 76X3719 + FREE Hob Brite Cleaner
Quality compatible spare part for a range of Candy and Hoover Cooker and Ovens. More InformationIn stockIn stockSpecial Price £10.49 Regular Price £39.99 -
Microwave Turntable Plate - 270mm
Suitable for use on most Microwaves. Please check suitability before ordering. More InformationIn stockIn stock£11.99
