Brandt Heaters & Elements
Brandt Heaters & Elements used in popular appliances. There are a number of cheap low cost alternative Brandt Heaters & Elements as well as the genuine ones.
If you are unsure or can't find the Brandt Heaters & Elements that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Brandt Heaters & Elements forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Universal Cooker Fan Oven Element - Long Neck
Cooker Fan Oven Element - 2500 Watt - 062057004
Quality compatible replacement part for a range of Candy and Hoover Cooker and Ovens. More InformationIn stockIn stockSpecial Price £18.99 Regular Price £24.99 -
Cooker Fan Oven Element - 2000 Watt - 77X2277
Quality compatible replacement part for a range of Brandt, DeDietrich and Fagor Cooker and Ovens. More InformationIn stockIn stockSpecial Price £10.49 Regular Price £29.99 -
Homark Cooker Fan Oven Element - 2000 Watt - 77X6400
Suitable for a range of Brandt and other branded cookers. This Fan Oven Element is a high quality replacement spare part manufactured by a UK Whitegoods Approved Supplier More InformationIn stockIn stockSpecial Price £18.49 Regular Price £24.99
Finding Brandt Heaters & Elements can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Brandt Heaters & Elements or any other spare part please ask for assistance as we're only too happy to help you.
