Atag Hinges
Atag Hinges used in popular appliances. There are a number of cheap low cost alternative Atag Hinges as well as the genuine ones.
If you are unsure or can't find the Atag Hinges that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Atag Hinges forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Fridge Freezer Door Hinge Kit
Genuine hinge repair kit that can be used to replace a door hinge set on either an integrated fridge or integrated freezer models More InformationIn stockIn stock£67.49 -
Dishwasher Hinge Bearing
Genuine replacement part. Suitable for a range of Bosch, Neff and Siemens Dishwashers. More InformationIn stockIn stock£13.49 -
Cooker Right Hand Oven Door Hinge - 096785
Quality compatible replacement part for a range of Atag, Balay, Bosch, Gaggenau, Neff and Siemens Cooker and Ovens. More InformationIn stockIn stock£10.99 -
Cooker Door Hinge - Right Hand Side
Genuine replacement part. Suitable for a range of Bosch, Neff and Siemens Cooker and Ovens. More InformationIn stockIn stock£35.49 -
Pizza Oven Hinge Gam Newscan
Suitable for use on most Cooker and Ovens. Please check suitability before ordering. More InformationIn stockIn stock£22.99 -
Dishwasher Door Spring
Door hinge spring used on dishwasher models as listed More InformationIn stockIn stock£12.49 -
Fridge Freezer Door Pin Set
Genuine Bosch Spares replacement inner freezer compartment plastic door hinge to fit fridge models from Bosch, Neff and Siemens More InformationIn stockIn stock£7.49 -
Dishwasher Door Hinge
Genuine replacement fixing kit to fix the integrated dishwasher to the work surface More InformationIn stockIn stock£17.49 -
Cooker Door Hinge - Main Oven Left Hand Side
Genuine replacement part. Suitable for a range of Bosch, Neff and Siemens Cooker and Ovens. More InformationIn stockIn stock£37.99
Finding Atag Hinges can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Atag Hinges or any other spare part please ask for assistance as we're only too happy to help you.
