Holme
Washing Machine Dispenser Hose
Hose that runs from the soap dispenser to the tub or tank of the washing machine models shown and others as advised as can be found fitted to other makes and models More InformationIn stockIn stock£13.49 -
Washing Machine Temperature Sensor NTC
Genuine spare part for a range of Amica, Bush, Currys Essentials, Gorenje, Kenwood and other branded Washing Machines. More InformationIn stockIn stock£7.49 -
Cooker Selector Switch - Main Oven
Quality compatible spare part for a wide range of Cooker and Ovens. More InformationIn stockIn stock£31.99 -
Washing Machine Door Handle - Silver
Genuine spare part for a range of Amica, Bush, Currys Essentials, Gorenje, Kenwood and other branded Washing Machines. More InformationIn stockIn stock£3.49 -
Washing Machine Button
Button set used on the models as shown but please check serial numbers as different ones can be used on these models More InformationIn stockIn stock£7.99 -
Washing Machine Door Hinge
Genuine replacement washing machine door lock used on the makes and models as shown or as advised as will fit more that listed More InformationIn stockIn stock£23.99 -
Washing Machine Drive Belt - 1236J6
Genuine washing machine drive belt used on Vestel produced machines as shown or others as appropriate or advised More InformationIn stockIn stock£13.49 -
Dishwasher Drain Pump
This Hanyu B30-6A drain pump is used on the dishwasher models as shown but can also be found used on may other makes and models as advised More InformationIn stockIn stock£39.49 -
Oven selector switch used on the models as shown or as advised to control the various functions of the oven More InformationIn stockIn stock£31.49 -
Quality compatible spare part for a wide range of Washing Machines. More InformationIn stockIn stock£6.75
