Vax Tools
Vax Tools used in popular appliances. There are a number of cheap low cost alternative Vax Tools as well as the genuine ones.
If you are unsure or can't find the Vax Tools that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Vax Tools forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Vax Vacuum Cleaner Upholstery Cleaning Tool 32mm
Quality compatible replacement part for a range of Vax Vacuum Cleaners. More InformationIn stockIn stock£4.49 -
Vax Vacuum Cleaner Dusting Brush - 32mm
Vax Vacuum Cleaner Mini Turbo Tool - 1912626100
Quality compatible replacement part for a range of Vax Vacuum Cleaners. More InformationOut of stockOut of stock£9.99 -
Finding Vax Tools can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Vax Tools or any other spare part please ask for assistance as we're only too happy to help you.
