Vax Cleaner Heads
Vax Cleaner Heads used in popular appliances. There are a number of cheap low cost alternative Vax Cleaner Heads as well as the genuine ones.
If you are unsure or can't find the Vax Cleaner Heads that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Vax Cleaner Heads forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Vax ONEPWR Vacuum Cleaner Floor Cleaner Head
Replacement spare part suitable for Vax Vacuum Cleaners. Genuine part from the original manufacturer. More InformationOut of stockOut of stock£53.99 -
Vax Blade Vacuum Cleaner Motorhead PCB Module
Replacement spare part suitable for Vax Vacuum Cleaners. Genuine part from the original manufacturer. More InformationIn stockIn stock£20.99 -
Vax Blade Vacuum Cleaner Floor Tool Cleaner Head - Pet
Replacement spare part suitable for Vax Vacuum Cleaners. Genuine part from the original manufacturer. More InformationIn stockIn stock£53.99 -
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stock£14.49
Finding Vax Cleaner Heads can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Vax Cleaner Heads or any other spare part please ask for assistance as we're only too happy to help you.
