Vax Vacuum Cleaner Accessories
Vax Vacuum Cleaner Accessories used in popular appliances. There are a number of cheap low cost alternative Vax Vacuum Cleaner Accessories as well as the genuine ones.
If you are unsure or can't find the Vax Vacuum Cleaner Accessories that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Vax Vacuum Cleaner Accessories forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Vax Vacuum Cleaner Upholstery Cleaning Tool 32mm
Quality compatible replacement part for a range of Vax Vacuum Cleaners. More InformationIn stockIn stock£4.49 -
Vax Vacuum Cleaner Dusting Brush - 32mm
Finding Vax Vacuum Cleaner Accessories can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Vax Vacuum Cleaner Accessories or any other spare part please ask for assistance as we're only too happy to help you.
