Numatic (Henry) Vacuum Cleaner Spare Parts
Numatic (Henry) Vacuum Cleaner spares for most leading brands including the most popular spare parts and many low-cost compatible or alternative spares where these are available.
Here you can find all the popular Numatic (Henry) Vacuum Cleaner parts and many more spares for your machine.
If you can't find the Numatic (Henry) Vacuum Cleaner spares you need or are unsure, please contact us for more help or you can use our Numatic (Henry) Vacuum Cleaner_support forum to get free help (including diagnostic and fault finding help) even outside business hours from engineers. By asking us by email we can often also cross reference spares and offer you more than one choice which will very often save you money on spare parts.
Vacuum Cleaner Floor Tool 32mm - Length 300mm - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Suitable for a range of Numatic Henry and other branded vacuum cleaners. This Floor Tool is a high quality replacement spare part manufactured by a UK Whitegoods Approved Supplier More InformationIn stockIn stockSpecial Price £12.49 Regular Price £14.99 -
Vacuum Cleaner Extension Tube & Bent End Kit - 32mm - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Quality compatible replacement part for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock -
Vacuum Cleaner Turbo Floor Tool 32mm - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models - 601226
Compatible red and black Numatic replacement airo power high performance brush for your Numatic vacuum cleaner More InformationIn stockIn stock -
Vacuum Cleaner Filter - 12 inch - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models - 604165
Quality compatible replacement part for a range of Numatic (Henry), Ovation and Quick Clean Vacuum Cleaners. More InformationIn stockIn stock -
Vacuum Cleaner Hose Tool End Cuff 32mm - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Genuine Numatic hose end cuff that is tapered to approximately 45 degrees to fit many of their popular cleaners fitted with a 32mm hose More InformationIn stockIn stock -
Vacuum Cleaner Rocker Switch - Made To Fit Numatic Henry Models
Quality compatible replacement part for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stockSpecial Price £6.25 Regular Price £15.99 -
Vacuum Cleaner Tool Kit - 32mm - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Quality compatible replacement part for a range of Numatic (Henry), Ovation and Quick Clean Vacuum Cleaners. More InformationIn stockIn stockSpecial Price £16.99 Regular Price £29.99 -
Vacuum Cleaner Hose & Attachment Tool Kit - 32mm - 2.5m Hose + Air Fresheners - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Suitable for a range of Numatic Henry Hetty James David Harry and Basil vacuums. This Tool Kit is a high-quality replacement spare part manufactured by a UK Whitegoods Approved Supplier. More InformationIn stockIn stockSpecial Price £27.49 Regular Price £41.99 -
Vacuum Cleaner Motor 620w - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models - DL1653T DL1553T
Single stage flow through motor used in Numatic cleaners More InformationOut of stockOut of stock£39.49 -
Numatic (Henry) Vacuum Cleaner Cable Rewind Contact Springs
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock
