Numatic (Henry) Vacuum Cleaner Cables & Leads
Numatic (Henry) Vacuum Cleaner Cables & Leads used in popular appliances. There are a number of cheap low cost alternative Numatic (Henry) Vacuum Cleaner Cables & Leads as well as the genuine ones.
If you are unsure or can't find the Numatic (Henry) Vacuum Cleaner Cables & Leads that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Numatic (Henry) Vacuum Cleaner Cables & Leads forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Vacuum Cleaner Flex 12m 1.0mm 2 Core Orange
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stock£26.49 -
Vacuum Cleaner Flex 7m 1.0mm 2 Core Grey Europlug
Vacuum Cleaner Cable Flex 15 Metre 1.5mm 2 Core
Suitable for a range of Numatic Henry and other branded vacuum cleaners. This Cable is a high quality replacement spare part manufactured by a UK Whitegoods Approved Supplier More InformationIn stockIn stock£40.99 -
Vacuum Cleaner Flex Cable 15 Metre 1.5mm 3 Core 13Amp
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stock£35.99 -
Numatic(Henry) Vacuum Cleaner Mains Cable
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£79.99
Finding Numatic (Henry) Vacuum Cleaner Cables & Leads can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Numatic (Henry) Vacuum Cleaner Cables & Leads or any other spare part please ask for assistance as we're only too happy to help you.
