Vacuum Cleaner Hose Ends & Cuffs
Vacuum Cleaner Hose Ends & Cuffs used in popular appliances. There are a number of cheap low cost alternative Vacuum Cleaner Hose Ends & Cuffs as well as the genuine ones.
If you are unsure or can't find the Vacuum Cleaner Hose Ends & Cuffs that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Vacuum Cleaner Hose Ends & Cuffs forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Vacuum Cleaner Hose End 51mm
Dyson DC14 Vacuum Cleaner Tool Adaptor
Quality compatible replacement part for a range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£5.99 -
Vacuum Cleaner Screw Body
Numatic (Henry) Vacuum Cleaner Threaded Neck - Yellow
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£9.49 -
Vacuum Cleaner Screw on Cuff
Quality compatible replacement part for a range of Candy, Hoover and Fagor Vacuum Cleaners. More InformationOut of stockOut of stock£6.99 -
Dyson DC21 Vacuum Cleaner Wand Cuff Cover
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£1.99 -
Vacuum Cleaner Hose End Adaptor
Quality compatible replacement part for a range of AEG, Electrolux, Parkinson Cowan and Zanussi Vacuum Cleaners. More InformationOut of stockOut of stock£4.49
Finding Vacuum Cleaner Hose Ends & Cuffs can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Vacuum Cleaner Hose Ends & Cuffs or any other spare part please ask for assistance as we're only too happy to help you.
