Vacuum Cleaner Handles
Vacuum Cleaner Handles used in popular appliances. There are a number of cheap low cost alternative Vacuum Cleaner Handles as well as the genuine ones.
If you are unsure or can't find the Vacuum Cleaner Handles that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Vacuum Cleaner Handles forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Premiere Vacuum Cleaner Hose Handle Bent End - Metal - 32mm
Quality compatible replacement part for a range of Premiere Vacuum Cleaners. More InformationOut of stockOut of stock£29.99 -
Sebo Dart Vacuum Cleaner Handle
Suitable for a range of Sebo Vacuum Cleaners. Genuine replacement part. More InformationIn stockIn stock£25.99 -
Sebo Dart Vacuum Cleaner Handle - Without Switch
Suitable for a range of Sebo Vacuum Cleaners. Genuine replacement part. More InformationOut of stockOut of stock£44.99 -
Vax Vacuum Cleaner Handle Assembly - Blue - U91P5E
Genuine replacement part. Suitable for a range of Vax Vacuum Cleaners. More InformationOut of stockOut of stock£17.49 -
Vax Vacuum Cleaner Handle Collar Assembly - VCU - 02
Genuine replacement part. Suitable for a range of Vax Vacuum Cleaners. More InformationOut of stockOut of stock£5.99 -
Vax Vacuum Cleaner Extension Tube & Tool Holder - Red
Genuine replacement part. Suitable for a range of Vax Vacuum Cleaners. More InformationIn stockIn stock£7.49 -
Numatic(Henry) Vacuum Cleaner Handle Cover
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£12.99
Finding Vacuum Cleaner Handles can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Vacuum Cleaner Handles or any other spare part please ask for assistance as we're only too happy to help you.
