Vacuum Cleaner Filters
Vacuum Cleaner Filters used in popular appliances. There are a number of cheap low cost alternative Vacuum Cleaner Filters as well as the genuine ones.
If you are unsure or can't find the Vacuum Cleaner Filters that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Vacuum Cleaner Filters forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Dyson DC50 Vacuum Cleaner Pre Motor Filter
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£24.99 -
Numatic (Henry) Vacuum Cleaner Filter
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£38.49 -
Bosch Vacuum Cleaner Inner Filter
Genuine replacement part. Suitable for a range of Bosch Vacuum Cleaners. More InformationIn stockIn stock£7.99 -
Vacuum Cleaner Filter - Cut To Size - 300mm x 300mm
Quality compatible replacement part for a range of AEG, Electrolux, Parkinson Cowan and Zanussi Vacuum Cleaners. More InformationIn stockIn stock£5.75 -
Dyson DC18 Vacuum Cleaner Pre Motor Filter - 911685 - 01
Quality compatible replacement part for a range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£7.49 As low as £5.99 -
Vax Vacuum Cleaner Filter - 1712897900 (Kit)
Quality compatible replacement part for a range of Vax Vacuum Cleaners. More InformationIn stockIn stock -
Dyson DC07 Vacuum Cleaner Filter - Hepa
Quality compatible replacement part for a range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£2.99 -
Vacuum Cleaner Filter (Kit)
Dyson DC33 Vacuum Cleaner Hepa Filter
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£37.99 -
Dyson DC07 DC33 Vacuum Cleaner Filter Housing Seal - Pre Motor
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£2.49
Finding Vacuum Cleaner Filters can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Vacuum Cleaner Filters or any other spare part please ask for assistance as we're only too happy to help you.
