Switches
Switches used in popular appliances. There are a number of cheap low cost alternative Switches as well as the genuine ones.
If you are unsure or can't find the Switches that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Switches forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Vacuum Cleaner Switch Rocker With Neon Indicator
Quality compatible replacement part for a range of UK Whitegoods Vacuum Cleaners. More InformationIn stockIn stock£3.99 -
Numatic (Henry) Vacuum Cleaner Switch Rod
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£3.49 -
Vacuum Cleaner Switch Deflector
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stock£8.25 -
Qualtex AS300 Vacuum Cleaner Protect Switch
Suitable for a range of Qualtex AS300 vacuum cleaners. This switch is a genuine spare part made by the original manufacturer. More InformationIn stockIn stock£7.49 -
Vacuum Cleaner On-Off Push Switch
Genuine replacement spare part. Suitable for a range of Electrolux, AEG, Zanussi and other branded Vacuum Cleaners. More InformationOut of stockOut of stock£15.49 -
Zanussi Vacuum Cleaner On-Off Push Switch
Genuine replacement spare part. Suitable for a range of Electrolux, AEG, Zanussi and other branded Vacuum Cleaners. More InformationIn stockIn stock£5.49 -
Electrolux Vacuum Cleaner On-Off Switch
Genuine replacement spare part. Suitable for a range of Electrolux, AEG, Zanussi and other branded Vacuum Cleaners. More InformationIn stockIn stock£13.49 -
Suitable for a range of Hoover and other branded vacuum cleaners. This Switch is a high quality replacement spare part manufactured by a UK Whitegoods Approved Supplier More InformationOut of stockOut of stock£6.99 -
Dyson DC04 Vacuum Cleaner Micro Switch
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£29.99 -
Dyson DC18 Vacuum Cleaner Micro Switch Housing Assembly
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£4.49
Finding Switches can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Switches or any other spare part please ask for assistance as we're only too happy to help you.
