Siemens Tools
Siemens Tools used in popular appliances. There are a number of cheap low cost alternative Siemens Tools as well as the genuine ones.
If you are unsure or can't find the Siemens Tools that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Siemens Tools forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stock£14.49
Finding Siemens Tools can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Siemens Tools or any other spare part please ask for assistance as we're only too happy to help you.
