Sebo Tools
Sebo Tools used in popular appliances. There are a number of cheap low cost alternative Sebo Tools as well as the genuine ones.
If you are unsure or can't find the Sebo Tools that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Sebo Tools forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Sebo Vacuum Cleaner Tool Kit - 1092DG
Quality compatible replacement part for a range of Sebo Vacuum Cleaners. More InformationIn stockIn stock£10.49 -
Sebo X & C Vacuum Cleaner Upholstery Tool 36.5mm
Quality compatible replacement part for a range of Sebo Vacuum Cleaners. More InformationIn stockIn stock£4.49 -
Sebo Vacuum Cleaner Radiator Brush - Felix Range - 1496GY
Suitable for a range of Sebo Felix vacuum cleaners. This radiator brush is a quality compatible replacement part made by a UK Whitegoods Approved Supplier. More InformationIn stockIn stockSpecial Price £8.49 Regular Price £15.99
Finding Sebo Tools can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Sebo Tools or any other spare part please ask for assistance as we're only too happy to help you.
