Numatic (Henry) Hoses
Numatic (Henry) Hoses used in popular appliances. There are a number of cheap low cost alternative Numatic (Henry) Hoses as well as the genuine ones.
If you are unsure or can't find the Numatic (Henry) Hoses that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Numatic (Henry) Hoses forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Vacuum Cleaner Extendible Hose 9m 32mm - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Quality compatible replacement part for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£21.49 -
Vacuum Cleaner Hose Ring Click 32mm
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stock£2.75 -
Vacuum Cleaner Hose & Attachment Tool Kit - 32mm - 2.5m - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Suitable for a range of Numatic Henry and other branded vacuum cleaners. This Tool Kit is a high quality replacement spare part manufactured by a UK Whitegoods Approved Supplier More InformationIn stockIn stockSpecial Price £33.49 Regular Price £43.99 -
Vacuum Cleaner Hose 40mm 2.5m
Vacuum Cleaner Hose - 38mm - 2.5m - Made To Fit Numatic WVD900 Models
Vacuum Cleaner Hose and Attachment Kit - 38mm - Suitable for Numatic Vacuum Cleaners
Replacement spare part suitable for Numatic Vacuum Cleaners. Compatible part made by a Uk Whitegoods Approved Supplier . More InformationIn stockIn stockSpecial Price £45.99 Regular Price £79.99 -
Vacuum Cleaner Hose - 32mm - 3m - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Replacement spare part suitable for Numatic Henry Vacuum Cleaners. Compatible part made by a Uk Whitegoods Approved Supplier. More InformationIn stockIn stockSpecial Price £13.99 Regular Price £23.99 -
Vacuum Cleaner Hose - High Visibilty - 38mm 3m
High visibility compatible Numatic vacuum cleaner hose to fit Henry's etc More InformationIn stockIn stockSpecial Price £21.49 Regular Price £29.99 -
Numatic (Henry) Vacuum Cleaner Hose Connector - Blue - Threaded
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£9.49
Finding Numatic (Henry) Hoses can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Numatic (Henry) Hoses or any other spare part please ask for assistance as we're only too happy to help you.
