Numatic (Henry) Accessories
Numatic (Henry) Accessories used in popular appliances. There are a number of cheap low cost alternative Numatic (Henry) Accessories as well as the genuine ones.
If you are unsure or can't find the Numatic (Henry) Accessories that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Numatic (Henry) Accessories forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
32mm Vacuum Cleaner Crevice Tool - 32mm - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Quality compatible replacement part for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£7.99 -
Numatic (Henry) Vacuum Cleaner Floor Tool
Genuine Numatic vacuum floor tool with dual pedals to adjust the height, c-clip and an extended neck elbow More InformationIn stockIn stock£30.99 -
Vacuum Cleaner 32mm Tool Kit - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Quality compatible replacement part for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stockSpecial Price £10.99 Regular Price £14.99 -
Vacuum Cleaner AP Nozzle Tool 35mm With Lint 122mm
Low cost upholstery nozzle to fit 35mm vacuum cleaner hoses from most popular brands such as AEG, Miele, Bosch and many more More InformationIn stockIn stock£5.49 -
Numatic (Henry) Vacuum Cleaner Turbo Tool - Black
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£37.99 -
Finding Numatic (Henry) Accessories can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Numatic (Henry) Accessories or any other spare part please ask for assistance as we're only too happy to help you.
