Karcher Vacuum Cleaner Cleaner Heads
Karcher Vacuum Cleaner Cleaner Heads used in popular appliances. There are a number of cheap low cost alternative Karcher Vacuum Cleaner Cleaner Heads as well as the genuine ones.
If you are unsure or can't find the Karcher Vacuum Cleaner Cleaner Heads that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Karcher Vacuum Cleaner Cleaner Heads forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Karcher Vacuum Narrow Floor Tool 35mm
Genuine replacement part. For a range of Karcher Vacuum Cleaners. More InformationOut of stockOut of stock£23.99 -
Finding Karcher Vacuum Cleaner Cleaner Heads can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Karcher Vacuum Cleaner Cleaner Heads or any other spare part please ask for assistance as we're only too happy to help you.
