Numatic (Henry) Vacuum Cleaner Hoses
Numatic (Henry) Vacuum Cleaner Hoses used in popular appliances. There are a number of cheap low cost alternative Numatic (Henry) Vacuum Cleaner Hoses as well as the genuine ones.
If you are unsure or can't find the Numatic (Henry) Vacuum Cleaner Hoses that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Numatic (Henry) Vacuum Cleaner Hoses forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Vacuum Cleaner Hose - 38mm - 3m - Made To Fit Numatic George Vacuum Cleaners
Quality compatible replacement part for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stockSpecial Price £26.99 Regular Price £33.49 -
Numatic(Henry) Vacuum Cleaner Hose Connector Flange
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£14.49 -
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stock£24.49 -
32mm Vacuum Cleaner Hose Coil - 20m - Made To Fit Numatic Henry Models
32mm Vacuum Cleaner Hose coil - 20m.‚ Quality spare part made by a UK Whitegoods Approved Supplier. More InformationIn stockIn stock£55.49 -
Vacuum Cleaner Hose Assembly 5m 38mm Box Of x10 - Made To Fit Numatic George Vacuum Cleaners
Quality compatible replacement part for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£163.99 -
Numatic(Henry) Vacuum Cleaner Hose Connector - 38mm
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£17.49 -
Vacuum Cleaner Hose End Bent 32mm
32mm Vacuum Cleaner Hose Coil - 10m
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stockSpecial Price £31.49 Regular Price £39.99 -
Numatic(Henry) Vacuum Cleaner Extraction Hose - 3m
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£97.49
Finding Numatic (Henry) Vacuum Cleaner Hoses can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Numatic (Henry) Vacuum Cleaner Hoses or any other spare part please ask for assistance as we're only too happy to help you.
