Hometek Vacuum Cleaner Hoses
Hometek Vacuum Cleaner Hoses used in popular appliances. There are a number of cheap low cost alternative Hometek Vacuum Cleaner Hoses as well as the genuine ones.
If you are unsure or can't find the Hometek Vacuum Cleaner Hoses that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Hometek Vacuum Cleaner Hoses forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Vacuum Cleaner Hose - HT108
Quality compatible replacement part for a range of Hometek and Powersonic Vacuum Cleaners. More InformationIn stockIn stock£12.49 -
Vacuum Cleaner Cleanfix Hose
Hometek HT689 Vacuum Cleaner Hose
Quality compatible replacement part for a range of Hometek Vacuum Cleaners. More InformationOut of stockOut of stock£10.99 -
Vacuum Cleaner Hose
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stock£10.99
Finding Hometek Vacuum Cleaner Hoses can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Hometek Vacuum Cleaner Hoses or any other spare part please ask for assistance as we're only too happy to help you.
