Numatic (Henry) Vacuum Cleaner Handles
Numatic (Henry) Vacuum Cleaner Handles used in popular appliances. There are a number of cheap low cost alternative Numatic (Henry) Vacuum Cleaner Handles as well as the genuine ones.
If you are unsure or can't find the Numatic (Henry) Vacuum Cleaner Handles that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Numatic (Henry) Vacuum Cleaner Handles forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Numatic(Henry) Vacuum Cleaner Handle Spacer
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationOut of stockOut of stock£9.49 -
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£16.49 -
Numatic(Henry) Vacuum Cleaner Handle Cover & Push Switch
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£61.99 -
Numatic(Henry) Vacuum Cleaner Wand Assembly - 1220mm - S/Steel
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£63.49 -
Numatic(Henry) Vacuum Cleaner Bucket Handle
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£15.49 -
Numatic(Henry) Vacuum Cleaner Lifting Handle
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£14.99 -
Numatic(Henry) Vacuum Cleaner Elbow Pedal Assembly - 32mm - NVA229A
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationIn stockIn stock£23.49 -
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationOut of stockOut of stock£12.99
Finding Numatic (Henry) Vacuum Cleaner Handles can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Numatic (Henry) Vacuum Cleaner Handles or any other spare part please ask for assistance as we're only too happy to help you.
