Extension Tubes
Extension Tubes used in popular appliances. There are a number of cheap low cost alternative Extension Tubes as well as the genuine ones.
If you are unsure or can't find the Extension Tubes that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Extension Tubes forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Dyson V10 V11 Vacuum Cleaner Short Wand - 655mm - Iron
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£43.49 -
Dyson DC35 Vacuum Cleaner Extension Tube - 920506-01
Quality compatible replacement part for a range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£21.49 -
Dyson V7(SV11) Vacuum Cleaner Quick Release Wand Assembly - Purple
Dyson V7(SV11) V8(SV10) Vacuum Cleaner Extension Tube - Fuchsia - 967477-05
Quality compatible replacement part for a range of Dyson Vacuum Cleaners. More InformationIn stockIn stockSpecial Price £27.49 Regular Price £33.99 -
Dyson V10(SV12) Vacuum Cleaner Short Wand Assembly
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationOut of stockOut of stock£55.49 -
Dyson UP22 UP32 Vacuum Cleaner Wand Handle - Silver & Red
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£23.49 -
Dyson DC47 DC49 DC56 Vacuum Cleaner Spring Extension Tube Catch
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationOut of stockOut of stock£2.99 -
Vacuum Cleaner Extension Tube - Chrome - 35mm
Karcher Steam Cleaner Extension Tube
Genuine replacement part. For a range of Karcher Steam Cleaners. More InformationIn stockIn stock£11.99 -
Vacuum Cleaner Extension Tube Kit - 38mm - Stainless Steel - Made To Fit Numatic George Vacuum Cleaners
Quality compatible replacement part for a range of Numatic (Henry), Ovation and Quick Clean Vacuum Cleaners. More InformationIn stockIn stock£23.49
Finding Extension Tubes can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Extension Tubes or any other spare part please ask for assistance as we're only too happy to help you.
