Cleaner Heads
Cleaner Heads used in popular appliances. There are a number of cheap low cost alternative Cleaner Heads as well as the genuine ones.
If you are unsure or can't find the Cleaner Heads that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Cleaner Heads forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Vax ONEPWR Vacuum Cleaner Floor Cleaner Head
Replacement spare part suitable for Vax Vacuum Cleaners. Genuine part from the original manufacturer. More InformationOut of stockOut of stock£53.99 -
Dyson V6 Vacuum Cleaner Compatible Motorized Floor Tool
Replacement spare part suitable for Dyson Vacuum Cleaners. Compatible part made by a UK Whitegoods Approved Supplier. More InformationIn stockIn stockSpecial Price £50.49 Regular Price £70.49 -
Dyson WR01 Wet Floor Cleaner Head Front Cover
Replacement spare part suitable for Dyson Vacuum Cleaners. Genuine part from the original manufacturer. More InformationIn stockIn stock£17.99 -
Dyson WR01 Wet Floor Cleaner Head Rear Cover
Vax Blade Vacuum Cleaner Motorhead PCB Module
Replacement spare part suitable for Vax Vacuum Cleaners. Genuine part from the original manufacturer. More InformationIn stockIn stock£20.99 -
Dyson WR01 Carpet Cleaner Head Shell
Replacement spare part suitable for Dyson Vacuum Cleaners. Genuine part from the original manufacturer. More InformationIn stockIn stock£45.99 -
Vax Blade Vacuum Cleaner Floor Tool Cleaner Head - Pet
Replacement spare part suitable for Vax Vacuum Cleaners. Genuine part from the original manufacturer. More InformationIn stockIn stock£53.99 -
Dyson UP24 Vacuum Cleaner Head
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£97.99 -
32mm Vacuum Cleaner Floor Tool - Single Pedal - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Quality compatible replacement part for a range of Numatic (Henry), Ovation and Quick Clean Vacuum Cleaners. More InformationIn stockIn stock£14.49 -
Finding Cleaner Heads can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Cleaner Heads or any other spare part please ask for assistance as we're only too happy to help you.
