Numatic (Henry) Vacuum Cleaner Cleaner Heads
Numatic (Henry) Vacuum Cleaner Cleaner Heads used in popular appliances. There are a number of cheap low cost alternative Numatic (Henry) Vacuum Cleaner Cleaner Heads as well as the genuine ones.
If you are unsure or can't find the Numatic (Henry) Vacuum Cleaner Cleaner Heads that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Numatic (Henry) Vacuum Cleaner Cleaner Heads forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Numatic (Henry) Vacuum Cleaner Floor Tool
Genuine Numatic vacuum floor tool with dual pedals to adjust the height, c-clip and an extended neck elbow More InformationIn stockIn stock£30.99 -
Finding Numatic (Henry) Vacuum Cleaner Cleaner Heads can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Numatic (Henry) Vacuum Cleaner Cleaner Heads or any other spare part please ask for assistance as we're only too happy to help you.
