Numatic (Henry) Cleaner Heads
Numatic (Henry) Cleaner Heads used in popular appliances. There are a number of cheap low cost alternative Numatic (Henry) Cleaner Heads as well as the genuine ones.
If you are unsure or can't find the Numatic (Henry) Cleaner Heads that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Numatic (Henry) Cleaner Heads forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
35mm Vacuum Cleaner Floor Tool - 270mm - 35601161
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stockSpecial Price £12.99 Regular Price £15.99 -
32mm Vacuum Cleaner Floor Tool - 270mm - Wessel Werk - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Suitable for a range of Numatic Henry and other branded vacuum cleaners. This Floor Tool is a high quality replacement spare part manufactured by a UK Whitegoods Approved Supplier More InformationIn stockIn stockSpecial Price £15.49 Regular Price £21.99 -
32mm Vacuum Cleaner Floor Tool - Single Pedal - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Quality compatible replacement part for a range of Numatic (Henry), Ovation and Quick Clean Vacuum Cleaners. More InformationIn stockIn stock£14.49 -
Vacuum Cleaner Floor Tool 305mm - 32mm - Made To Fit Henry, Hetty, James, David, Harry, Basil Models
Suitable for a range of Numatic Henry and other branded vacuum cleaners. This Floor Tool is a high quality replacement spare part manufactured by a UK Whitegoods Approved Supplier More InformationIn stockIn stockSpecial Price £17.49 Regular Price £29.99
Finding Numatic (Henry) Cleaner Heads can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Numatic (Henry) Cleaner Heads or any other spare part please ask for assistance as we're only too happy to help you.
