Cables & Leads
Cables & Leads used in popular appliances. There are a number of cheap low cost alternative Cables & Leads as well as the genuine ones.
If you are unsure or can't find the Cables & Leads that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Cables & Leads forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Kirby Vacuum Cleaner Rubber Mains Cable 10m
Quality compatible replacement part for a range of Kirby Vacuum Cleaners. More InformationIn stockIn stock£21.49 -
Truvox Vacuum Cleaner Flex 12m 1.0mm 3 Core Angled Plug
Quality compatible replacement part for a range of Truvox Vacuum Cleaners. More InformationIn stockIn stock£27.99 -
Beko Washing Machine Main Cable Harness
Replacement spare part for a range of Beko Washing Machines. Genuine part from the original manufacturer. More InformationIn stockIn stock£117.99 -
Truvox Vacuum Cleaner Cable Flex 15m 1.5mm 3 Core 16A
Quality compatible replacement part for a range of Truvox Vacuum Cleaners. More InformationIn stockIn stock£32.99 -
Numatic (Henry) Vacuum Cleaner Cable Moulding
Genuine replacement part. Suitable for a range of Numatic (Henry) Vacuum Cleaners. More InformationOut of stockOut of stock£4.49 -
Kirby Vacuum Cleaner Mains Cable Flex 10m
Quality compatible replacement part for a range of Kirby Vacuum Cleaners. More InformationIn stockIn stock£17.49 -
Victor Vacuum Cleaner Flex Cable Plug In Lead 12m 2 Core
Quality compatible replacement part for a range of Victor Vacuum Cleaners. More InformationIn stockIn stock£22.49 -
Dyson DC50 Vacuum Cleaner Mains Power Cable
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationOut of stockOut of stock£34.49 -
Vacuum Cleaner Flex 12m 1.0mm 2 Core Orange
Suitable for use on most Vacuum Cleaners. Please check suitability before ordering. More InformationIn stockIn stock£26.49
Finding Cables & Leads can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Cables & Leads or any other spare part please ask for assistance as we're only too happy to help you.
