Cables & Leads
Cables & Leads used in popular appliances. There are a number of cheap low cost alternative Cables & Leads as well as the genuine ones.
If you are unsure or can't find the Cables & Leads that you are looking for please contact us and we will be only too happy to help you locate the part for any branded appliance.
For technical support please use the Cables & Leads forum where you can get expert help from engineers. There is also a lot more help and advice about faults in the help section of the website.
Dyson DC25 Vacuum Cleaner Cable - 914269-16
Quality compatible replacement part for a range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£14.99 -
Vacuum Cleaner Flex Cable 1.00mm 12m Length - Made To Fit Numatic Henry, Hetty, James, David, Harry, Basil Models
Suitable for a range of vacuum cleaners. This is a quality replacement spare part made by a UK Whitegoods Approved Supplier. More InformationIn stockIn stock£23.49 -
Floor Polisher Mains Cable Flex - 20m - Black - Made To Fit Numatic Models
Suitable for a range of Numatic floor polishers. This flex is a quality replacement spare part made by a UK Whitegoods Approved Supplier. More InformationIn stockIn stock£35.99 -
Vax Vacuum Cleaner Cable Rewind Assembly - C89 - P6
Genuine replacement part. Suitable for a range of Vax Vacuum Cleaners. More InformationOut of stockOut of stock£26.49 -
Dyson DC40ERP DC42ERP Vacuum Cleaner Yoke Cable Assembly
Genuine replacement part for a select range of Dyson Vacuum Cleaners. More InformationIn stockIn stock£4.49 -
Vacuum Cleaner Flex 12m 1.0mm 2 Core 13 Amp
Numatic Vacuum Cleaner Mains Cable - 12.5m - 1mm
Replacement spare part suitable for Numatic Vacuum Cleaners. Genuine part from the original manufacturer. More InformationIn stockIn stock£64.99 -
Numatic Henry Vacuum Cleaner Mains Cable - 10m - 1mm
Replacement spare part suitable for Numatic Vacuum Cleaners. Genuine part from the original manufacturer. More InformationIn stockIn stock£34.99 -
Karcher Vacuum Cleaner Yellow Mains Cable - 12m
Replacement spare part suitable for Karcher Vacuum Cleaners. Genuine part from the original manufacturer. More InformationIn stockIn stock£65.99 -
Dyson DC01 DC07 DC04 Vacuum Cleaner Cable Flex 8m
Finding Cables & Leads can be hard as they are often very specific to a model or even a production run, even if they look alike. Please see this page for general help in how to get the correct parts that you need. If you need help to find any Cables & Leads or any other spare part please ask for assistance as we're only too happy to help you.
