Cables & Cable Management
Dekton High Vis Cable Ties (Pack of 50)
Dekton High Vis Cable Ties (Pack of 50) More InformationIn stockIn stock£4.99 As low as £3.99 -
Benross 4 Gang Extension Trailing Socket - 1 Metre
Benross 4 Gang Extension Trailing Socket - 1 Metre More InformationOut of stockOut of stock£7.99 -
Jegs 2 Way Mains Plug In Adaptor - 13A
Jegs 2 Way Mains Plug In Adaptor - 13A More InformationIn stockIn stock£5.49 As low as £3.99 -
Jegs Round Cable Clips - 8mm - White (Pack of 100)
Jegs Round Cable Clips - 8mm - White (Pack of 100) More InformationIn stockIn stock£5.49 As low as £3.99 -
Jegs Twin & Earth Cable Clips - 2.5mm (Pack of 10)
Jegs Twin and Earth Cable Clips - 2.5mm (Pack of 10) More InformationIn stockIn stock£1.99 As low as £0.99 -
Jegs Twin & Earth Cable - 6242Y - 1mm - 5 Metre
Jegs Twin and Earth Cable - 6242Y - 1mm - 5 Metre More InformationOut of stockOut of stock£8.49 -
Jegs Twin & Earth Cable - 6242Y - 1.5mm - 5 Metre
Jegs Twin and Earth Cable - 6242Y - 1.5mm - 5 Metre More InformationIn stockIn stock£9.49 -
Jegs Twin & Earth Cable - 6242Y - 2.5mm - 5 Metre
Jegs Twin and Earth Cable - 6242Y - 2.5mm - 5 Metre More InformationIn stockIn stock£9.99 -
Jegs Twin & Earth Cable - 6242Y - 6mm - 2 Metre
Jegs Twin and Earth Cable - 6242Y - 6mm - 2 Metre More InformationIn stockIn stock£10.99 -
Jegs Twin & Earth Cable - 6242Y - 6mm - 5 Metre
Jegs Twin and Earth Cable - 6242Y - 6mm - 5 Metre More InformationIn stockIn stock£23.49
