Bush
Cooker Oven Door Roller Catch
Oven door lock used on oven doors on the built in oven and cooker models as shown or as directed More InformationIn stockIn stock£6.99 -
Freezer Compartment Door Handle
Fridge door handle with latch to fit the fridge models as shown or others as advised More InformationIn stockIn stock£11.49 -
Universal Washing Machine Bearing - 6201ZZ
Suitable for use on most Washing Machines. Please check suitability before ordering. More InformationIn stockIn stock£7.49 -
Washing Machine Sump Hose
Genuine replacement sump hose that connects from the bottom of the tub to tank of the washing machine to the drain pump housing on the models as shown More InformationIn stockIn stock£25.49 -
Washing Machine Drum Paddle Clothes Lifter (Pack of 3)
Quality compatible replacement part for a range of Bush, Currys Essentials, Daewoo, Logik, Montpellier, Servis, Sharp and Swan Washing Machines. More InformationIn stockIn stock£9.99 -
Vacuum Cleaner Hose End 51mm
Cooker Energy Regulator - 5 Position - 050032
Low cost compatible oven function selector switch to fit Delonghi manufactured built in oven models listed or as advised as can fit more models than listed More InformationIn stockIn stock£16.49
