Blue Sky
Washing Machine Drain Hose
Drain hose or water outlet pipe with the special end fitting to fit the models of washing machine and washer dryer as shown but can be found on other makes and models not listed More InformationIn stockIn stock£14.49 -
Washing Machine Heater Element - 1850W
Genuine replacement washing machine heating element to fit the various washing machine models as shown or as directed More InformationIn stockIn stock£13.99 -
Washing Machine Drum Lifter
Genuine replacement dum paddle or lifter to fit the washing machine and washer dryer models as shown More InformationIn stockIn stock£9.99 -
Washing Machine Solenoid Valve - 12mm 180 Degree
Low cost compatible twin solenoid water inlet or fill valve to fit Beko, Candy and many other washing machine models as shown or as advised More InformationIn stockIn stock£40.49 -
Cooker Selector Switch - 9 Tag
Quality compatible spare part for a wide range of Cooker and Ovens. More InformationIn stockIn stock£21.49 -
Washing Machine Dispenser Hose
Hose that runs from the soap dispenser to the tub or tank of the washing machine models shown and others as advised as can be found fitted to other makes and models More InformationIn stockIn stock£13.49 -
Washing Machine Temperature Sensor NTC
Genuine spare part for a range of Amica, Bush, Currys Essentials, Gorenje, Kenwood and other branded Washing Machines. More InformationIn stockIn stock£7.49 -
Washing Machine Door Handle - Silver
Genuine spare part for a range of Amica, Bush, Currys Essentials, Gorenje, Kenwood and other branded Washing Machines. More InformationIn stockIn stock£3.49 -
Washing Machine Door Hinge
Genuine replacement washing machine door lock used on the makes and models as shown or as advised as will fit more that listed More InformationIn stockIn stock£23.99 -
Washing Machine Drive Belt - 1236J6
Genuine washing machine drive belt used on Vestel produced machines as shown or others as appropriate or advised More InformationIn stockIn stock£13.49
